  • Page:
  • 1
  • 2
TOPIC: Problem with reading and transferring over USB
Problem with reading and transferring over USB 11 months 3 weeks ago #7562
David
34000 cover, for each file
Problem with reading and transferring over USB 11 months 3 weeks ago #7563
online
Thank you received: 544
Ok, send me just the library.ydb file inside .yacreaderlibrary that should be enough
Problem with reading and transferring over USB 11 months 3 weeks ago #7564
David
Problem with reading and transferring over USB 11 months 3 weeks ago #7565
online
Most of your comics have missing the "numPages" field in the data base. This is a mandatory field that is calculated when the comics are added to the library. There was a bug in a previous version of YACReaderLibrary what could delete this field if you use the "delete metadata function", but I am not sure if this is the problem or something else happened.
So, remove the library, delete the .yacreaderlibrary folder, and recreate the library, BUT make sure you have the latest version of YACReader installed (9.12)
The following user(s) said Thank You: David
Problem with reading and transferring over USB 11 months 3 weeks ago #7578
David
Thanks a lot, rebuild library is the answer ! Thnaks, thanks ! :woohoo:
Problem with reading and transferring over USB 11 months 3 weeks ago #7580
online
Please, keep me posted if it happens again, that information from the DB shouldn't disappear.
  • Page:
  • 1
  • 2
