TOPIC: Problems with Ubuntu 15.10 Wily 32-bit
Problems with Ubuntu 15.10 Wily 32-bit 8 years 4 months ago #1942
max6166
I have not had any luck building YAC on Ubuntu 15.10.
Ideally, I would prefer to run the headless library server version, but for now, I was just trying to build the GUI version with the "no_opengl" option.
The odd thing is that I think "qmake CONFIG+=no_opengl" still results in a build that looks for OpenGL?
If I run it over VNC it crashes with a "Could not initialize GLX" error.
If I run it directly on the machine, the initial screen launches then freezes with the following log:
2015-12-19 17:58:04.967 DEBUG TemplateLoader: path=/usr/share/yacreader/server/templates, codec=UTF-8
2015-12-19 17:58:04.967 DEBUG TemplateCache: timeout=60000, size=160000
2015-12-19 17:58:04.967 DEBUG HttpSessionStore: Sessions expire after 864000000 milliseconds
2015-12-19 17:58:04.967 DEBUG StaticFileController: docroot=/usr/share/yacreader/server/docroot, encoding=UTF-8, maxAge=60000
2015-12-19 17:58:04.967 DEBUG StaticFileController: cache timeout=60000, size=1000000
2015-12-19 17:58:04.967 DEBUG ServiceHelper: Starting service
2015-12-19 17:58:04.967 DEBUG HttpListener: Listening on port 8080
2015-12-19 17:58:04.967 DEBUG ServiceHelper: Service has started
2015-12-19 17:58:06.205 WARNING QOpenGLWidget: Cannot make uninitialized widget current
2015-12-19 17:58:06.223 WARNING QObject::connect: No such signal ClassicComicsView::doubleClicked(QModelIndex)
2015-12-19 17:58:06.536 WARNING QObject::connect: No such slot YACReaderOptionsDialog::restoreOptions()
2015-12-19 17:58:06.599 WARNING QObject::connect: No such slot ServerConfigDialog::openingError(QProcess::ProcessError)
2015-12-19 17:58:06.606 WARNING QObject::connect: No such signal LibraryCreator::failedUpdatingDB(QString)
Any ideas?
Last Edit: 8 years 4 months ago by max6166.
Problems with Ubuntu 15.10 Wily 32-bit 8 years 4 months ago #1943
selmf
Developer
Thank you received: 135
Hi max6166,
the no_opengl config option is intended for embedded systems that only support embedded OpenGL. It removes hard dependencies on desktop grade OpenGL. Since the Qt toolkit itself makes use of OpenGL for other stuff we can't remove it completely. So it's probably not what you're looking for ;)
I'm not sure what exactly happens in your build of YACReaderLibrary. QOpenGLWidget shouldn't be used with the no_opengl option. I'll have to setup a 32 bit virtual machine to test it - after the holidays.
P.S: Since you feel comfortable building YAC* yourself you might want to contact Luis regarding the headless version. It's still very much a work in progress (alpha or pre-alpha), but he might be interested in having a tester or two who are skilled enough to compile the code themself ;)
Last Edit: 8 years 4 months ago by selmf.
