- Thank you received: 6
Continue remote reading - wrong order
- purger500
5 years 2 months ago #6149
by purger500
Continue remote reading - wrong order was created by purger500
My iOS app updated today to v3.17.0.1 and from then there is wrong order of comics in Continue reading in the remote library.
For example, if I read comic1, and then comic2, and than comic3, right order (from left to right) will be 3,2,1. And it is in the right order until I exit app. When I start it again, order isn't right anymore, it is random (example: 2,3,1).
I noticed that reading list in YacReader library (version 9.8.2.2106261) is the same as it is on my iPad Pro, right until I exit iOS app, and wrong when I start again iOS app.
5 years 2 months ago #6150
Replied by Luis Ángel on topic Continue remote reading - wrong order
Hi, thanks for letting me know about this.
Where do you have those comics? are they part of a reading list? I can't reproduce the problem. Do you mind trying the production version instead of that dev build you are using? Just download it from the download section in the website.
- purger500
5 years 2 months ago #6151
by purger500
Replied by purger500 on topic Continue remote reading - wrong order
I tried production version and the problem persists. My comics are on my NAS storage (on local network), and they are not part of a reading list. To reproduce problem try to open comic1 and close it, open comic2 (from other directory) and close it, open comic3 (from other directory) and close it, open comic 4 (from other directory) and close it. Then look at "continue reading order". Then close iOS app and start it again. Order should be wrong.
Everything was fine before last update of iOS app.
Thank you for investigating.
5 years 2 months ago #6152
Hi, thanks for the info. That's exactly what I tried and I couldn't reproduce the problem.
Could you create a test library in your computer with a few folders and 1 or two comics in each folder and try again with that library?
- purger500
5 years 2 months ago - 5 years 2 months ago #6155
by purger500
Hi, I have just tried that. I have created 4 folders with 2 comics in each of them. I opened and closed comics in that order: folder1, folder2, folder3 and folder 4. Order in "continue reading" (from left to right) was: 4,3,2,1.
After I closed and reopened app, order was: 4,2,1,3.
Names of the files:
1. TEX 0649-650 (11-2014).cbr
2. DD 0359 (07-2016).cbr
3. ZAG 0626 (09-2017).cbr
4. Alan Ford 550 (04-2015).cbr
Names of the files:
Last edit: 5 years 2 months ago by purger500.
5 years 2 months ago #6156
Thanks! I will try exactly that.
- purger500
5 years 2 months ago #6157
by purger500
I am sending you my library.ydb file
- purger500
5 years 2 months ago #6158
by purger500
I just tried to install v3.17.0.1 from testflight, but unfortunately my problem persists. I will rename my comics in test library and try again.
- purger500
5 years 2 months ago #6159
by purger500
I narrowed the problem. It's not about name of files, but a name of folders.
I have created a new library with this structure:
TEX - ComicA 001.cbr and ComicA 002.cbr
DYLAN DOG - ComicB 001.cbr and ComicB 002.cbr
ZAGOR - ComicC 001.cbr and ComicC 002.cbr
ALAN FORD - ComicD 001.cbr and ComicD 002.cbr
I opened and closed comics in this order: ComicA 001, ComicB 001, ComicC 001, ComicD 001
Order (from left to right) was: ComicD, ComicC, ComicB, ComicA
After app closing an starting again: ComicD, ComicB, ComicA, ComicC
Then i renamed folders:
COMICA - ComicA 001.cbr and ComicA 002.cbr
COMICB - ComicB 001.cbr and ComicB 002.cbr
COMICC - ComicC 001.cbr and ComicC 002.cbr
COMICD - ComicD 001.cbr and ComicD 002.cbr
After app closing an starting again: ComicA, ComicB, ComicC, ComicD
Sorry on the long post, but I am trying to narrow the problem.
5 years 1 month ago #6161
Thank you very much for all the digging. I can now reproduce the problem!! I will ping you once I have a fix.
