YACReader 9.6.0 release candidate
CHANGELOG:
- Fastest sync back from iOS
- RAR5 support
- Option to hide current/next comic banner in the grid view
- Fix saving progress when reading in double page mode
- Fix some issues in magnifying glass when used in hdpi screens
- Fixes in Comic Vine integration
- Other fixes and stability improvements
I know you are all waiting for some more exciting features, but there are a good a mount of non visible work that will help to get things done faster in the future.
macos: www.dropbox.com/s/r29fmw6t68x3er9/YACRea...acOSX-Intel.dmg?dl=0
windows x64: www.dropbox.com/s/u4kqnbz13oj6vvl/YACRea...3-winx64-7z.exe?dl=0
- Drybonz
- Thank you received: 3
I am wondering if the subfolders can be shown as the comic boxes with the top cover image, like in the ios app, instead of a text list. I think this looks nice on the ios app and would be a lot better than the text list for subfolders. Just a suggestion.
Keep up the good work man... it is getting better all the time.
- Drybonz
Luis Ángel wrote: Yes, I have plans to do that, the list was a workaround. There are a bunch of more pressing things I have to take care before doing this though.
Sounds good. Any suggestions I make are just ideas you can use as you see fit. Please don't feel like it's a request to add them as soon as possible.
Also... with the development builds, are there any release notes or things we should be looking to test with the new builds?
Luis Ángel wrote: Latest build includes "Close to system tray" feature, it has to be enabled in the settings. Let me know how it works on your systems.
Yes, please do. Luis and I went through hell getting this working "just right" on all of the supported platforms, and we're kind of waiting for the first tester to horribly break it
- Drybonz
