OS X 10.9: renderer problem
  • fbaier
12 years 10 months ago - 12 years 10 months ago #308 by fbaier
OS X 10.9: renderer problem was created by fbaier
Hey Luis,
is it possible, that the YACreader has a little problem with the rendering of images at the 6.5.3 ?
I made a screenshot with YACreader and the Simple Viewer to compare both images.
Link: www.dropbox.com/sh/9hd5qnlg9inpwlg/xDbmcjOU_4
Last edit: 12 years 10 months ago by fbaier.
12 years 10 months ago #309 by Luis Ángel
Replied by Luis Ángel on topic OS X 10.9: renderer problem
Please, press W to see the pages in fullsize (original image resolution). I am not sure if Simple Viewer has the same option.
same result?
It could be something related with retina display and/or mavericks.
Thank you for your help.
  • fbaier
12 years 6 months ago - 12 years 6 months ago #438 by fbaier
Replied by fbaier on topic OS X 10.9: renderer problem
Hello Luis,
it's been a while since my last login. I had a lot to do. Sorry.
I found the problem at Mavericks and I want to share the solution.
Mavericks has a problem with the font smoothing.
Link: apple.stackexchange.com/questions/106497...o-with-high-res-disp
In this link is the solution to correct the font smoothing problem at YACReader.
I just want to add this link which also makes the YACReader fonts better to read:
etherealmind.com/mac-os-x-disable-lcd-fo...oothing-on-mac-os-x/
Last edit: 12 years 6 months ago by fbaier.
