Problems with webtoon/Manhwa
  • SrCaraDePapa
3 years 9 months ago - 3 years 9 months ago #7331 by SrCaraDePapa
Problems with webtoon/Manhwa was created by SrCaraDePapa
The problem would be that when I visualize my webtoon/manhwa the quality is reduced too much, at first I thought that the cause of the problem would be the too big resolution of the images that usually are aprox: (1500x10000 ^) Which is strange to me because I always scale my images x2 and reduce the noise with AI to get the best quality possible.
Trying to solve this problem I split the images in 3 parts solving the previous problem but getting a new problem, which would be to have multiple separations in the images in the form of a horizontal division (not in all).
I show both problems in the following images.
Last edit: 3 years 9 months ago by Luis Ángel.
3 years 9 months ago #7338 by Luis Ángel
Replied by Luis Ángel on topic Problems with webtoon/Manhwa
What device are you using? there is a limit in the image size depending on the device capabilities.
