- Thank you received: 2
Swipe left-to-right inside a folder broken
- thaddeusrock
11 months 1 day ago #9818
by thaddeusrock
Swipe left-to-right inside a folder broken was created by thaddeusrock
iPad (m4) on 26.2, YAC on. 3.36.0.1
Inside of a folder, where a LR swipe before brought up the quick delete “stripe”, now it just exits the folder (a souped up “go back” gesture, probably). Outside of a folder (ie, on the main screen), the LR swipe behaves as it used to.
Thanks!
Thanks!
11 months 1 day ago #9819
Replied by Luis Ángel on topic Swipe left-to-right inside a folder broken
I noticed it, but I haven't decided what to do. Delete can be accessed from the normal selection right-to-left too, so I am wondering if I should go against the grain or not with this one, fighting against Apple normally ends pretty bad.
Let's see if other users join the discussion.
- thaddeusrock
11 months 1 day ago #9820
by thaddeusrock
Replied by thaddeusrock on topic Swipe left-to-right inside a folder broken
While you CAN access the normal swipe menu, not being able to use the left to right means you can’t cancel that swipe stripe. So if I’m trying to delete or otherwise action on 40 items and swipe the wrong one, I need to start over from scratch.
10 months 4 weeks ago #9825
It'll be fixed in the next release, I'll try to publish it soon but I am having some troubles with Apple reviews lately so it could take long than expected.
The following user(s) said Thank You: thaddeusrock
- thaddeusrock
10 months 4 weeks ago #9826
by thaddeusrock
I can be patient - just happy to know it’s in the works.
Thank you so much!
Thank you so much!
