Mouse clicks not registering anymore in Grid View.
- Atomsk
2 months 1 week ago #10261
by Atomsk
Mouse clicks not registering anymore in Grid View. was created by Atomsk
YACReader - Yet Another Comic Reader - version 10.3.0.0
SYSTEM INFORMATION
Qt version: 6.11.1
Build ABI: x86_64-little_endian-lp64
build CPU architecture: x86_64
Kernel type: linux
Kernel version: 7.2.3-200.nobara.fc44.x86_64
Product info: KDE Flatpak runtime
since the most recent update, i can't click anything in the grid view. cursor navigation also does not work anymore. the comic covers register mouse-over, but that's it.
menus and the left library/folder bar still works, as does the comic flow view. but i find that view more than annoying and would prefer to not use it.
SYSTEM INFORMATION
Qt version: 6.11.1
Kernel type: linux
2 months 1 week ago #10262
Replied by Luis Ángel on topic Mouse clicks not registering anymore in Grid View.
I tested it with Qt 6.11.1 but I can't replicate the problem. I'll investigate what could be the problem.
2 months 1 week ago #10263
Does right click work?
- Atomsk
2 months 1 week ago #10264
by Atomsk
Replied by Atomsk on topic Mouse clicks not registering anymore in Grid View.
same behavior (or lack thereof) as the left mouse button.
2 months 1 week ago #10265
I set up a test environment to try the flatpak version and I am still unable to replicate the problem. Now that I know the right click has the same problem I can rule some things out.
2 months 1 week ago - 2 months 1 week ago #10266
if you run the app like this, do you see anything in the log after doing some clicks around?
then check both logs
flatpak run --command=YACReaderLibrary com.yacreader.YACReader --loglevel trace 2>&1 | tee /tmp/yacr.log
~/.var/app/com.yacreader.YACReader/data/YACReader/YACReaderLibrary/yacreaderlibrary.log
Last edit: 2 months 1 week ago by Luis Ángel.
- Atomsk
2 months 1 week ago - 2 months 1 week ago #10267
by Atomsk
when i try to click, these messages get logged:
also on launch, before clicking anything, there are some entries related to the gridview:
WARN 2026-09-08T14:59:04.942 qrc:/qml/GridComicsView.qml:178: TypeError: Property 'selectedItem' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.095 qrc:/qml/GridComicsView.qml:253: TypeError: Property 'setCurrentIndex' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.248 qrc:/qml/GridComicsView.qml:253: TypeError: Property 'setCurrentIndex' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.248 qrc:/qml/GridComicsView.qml:178: TypeError: Property 'selectedItem' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.420 qrc:/qml/GridComicsView.qml:253: TypeError: Property 'setCurrentIndex' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.610 qrc:/qml/GridComicsView.qml:253: TypeError: Property 'setCurrentIndex' of object GridComicsView(0x55cd568e48f0) is not a function
WARN 2026-09-08T14:59:05.610 qrc:/qml/GridComicsView.qml:178: TypeError: Property 'selectedItem' of object GridComicsView(0x55cd568e48f0) is not a function
INFO 2026-09-08T15:03:09.898 YACReaderLibrary starting
WARN 2026-09-08T15:03:10.002 qrc:/qml/GridComicsView.qml:451:21: ReferenceError: showCurrentComic is not defined
WARN 2026-09-08T15:03:10.003 qrc:/qml/GridComicsView.qml:461: ReferenceError: showCurrentComic is not defined
WARN 2026-09-08T15:03:10.003 qrc:/qml/GridComicsView.qml:474: TypeError: Property 'getCoverUrlPathForComicHash' of object GridContentModel(0x56083181b550) is not a function
WARN 2026-09-08T15:03:10.004 qrc:/qml/GridComicsView.qml:461: ReferenceError: showCurrentComic is not defined
WARN 2026-09-08T15:03:10.004 qrc:/qml/GridComicsView.qml:474: TypeError: Property 'getCoverUrlPathForComicHash' of object GridContentModel(0x56083181b550) is not a function
TRACE 2026-09-08T15:03:10.004 GridComicsView
WARN 2026-09-08T15:03:10.034 QMetaObject::invokeMethod: No such method QQuickRectangle_QML_35::capturePosition()
WARN 2026-09-08T15:03:10.040 qrc:/qml/GridComicsView.qml:111: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.040 qrc:/qml/GridComicsView.qml:149: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.040 qrc:/qml/GridComicsView.qml:364:21: Unable to assign [undefined] to QString
WARN 2026-09-08T15:03:10.041 qrc:/qml/GridComicsView.qml:474: TypeError: Property 'getCoverUrlPathForComicHash' of object GridContentModel(0x56083181b550) is not a function
WARN 2026-09-08T15:03:10.041 qrc:/qml/GridComicsView.qml:111: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.041 qrc:/qml/GridComicsView.qml:149: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.041 qrc:/qml/GridComicsView.qml:364:21: Unable to assign [undefined] to QString
WARN 2026-09-08T15:03:10.041 qrc:/qml/GridComicsView.qml:461: ReferenceError: showCurrentComic is not defined
WARN 2026-09-08T15:03:10.043 QMetaObject::invokeMethod: No such method QQuickRectangle_QML_35::capturePosition()
WARN 2026-09-08T15:03:10.047 qrc:/qml/GridComicsView.qml:474: TypeError: Property 'getCoverUrlPathForComicHash' of object GridContentModel(0x56083181b550) is not a function
WARN 2026-09-08T15:03:10.090 qrc:/qml/GridComicsView.qml:111: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.090 qrc:/qml/GridComicsView.qml:149: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.090 qrc:/qml/GridComicsView.qml:364:21: Unable to assign [undefined] to QString
WARN 2026-09-08T15:03:10.091 qrc:/qml/GridComicsView.qml:111: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.091 qrc:/qml/GridComicsView.qml:149: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.091 qrc:/qml/GridComicsView.qml:364:21: Unable to assign [undefined] to QString
WARN 2026-09-08T15:03:10.092 qrc:/qml/GridComicsView.qml:111: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.092 qrc:/qml/GridComicsView.qml:149: ReferenceError: dummyValue is not defined
WARN 2026-09-08T15:03:10.092 qrc:/qml/GridComicsView.qml:364:21: Unable to assign [undefined] to QString
Last edit: 2 months 1 week ago by Atomsk.
2 months 1 week ago #10268
I think something is off with your setup. It sounds like you have some stale files from a previous installation.
Send me what you get from running this.
And then you can try reinstalling it.
flatpak info
flatpak uninstall com.yacreader.YACReader
flatpak install flathub com.yacreader.YACReader
- Atomsk
2 months 1 week ago #10269
by Atomsk
that's the package info:
uninstalling and reinstalling did not change the behavior.
i tried removing libraries and metadata and that too had no effect.
then i tried installing the package provided via dnf. there it works again, but unfortunately that's only version 9.16.3.0.
YACReader - Yet another comic reader
Ref: app/com.yacreader.YACReader/x86_64/stable
Arch: x86_64
Branch: stable
Version: 10.3.0
License: GPL-3.0-only
Origin: flathub
Collection: org.flathub.Stable
Installation: user
Installed Size: 14,8 MB
Runtime: org.kde.Platform/x86_64/6.11
Sdk: org.kde.Sdk/x86_64/6.11
Commit: b9e8e53433c16267603c7fb091d26b07bf3726fc13240befc595faf3e674a832
Parent: 2d7ac2491897897420f28edca623c15ad4b7d7c147db0f8868e27c87bc55f229
Subject: Merge pull request #26 from YACReader/update-10.3 (60599d0e4a3b)
Date: 2026-09-01 17:19:00 +0000
2 months 1 week ago #10270
Then it's a cache problem.
Can you clean this?
Or run it with this setting:
Can you clean this?
~/.var/app/com.yacreader.YACReader/cache/YACReader/YACReaderLibrary/qmlcache/*.qmlc
flatpak run --env=QML_DISABLE_DISK_CACHE=1 --command=YACReaderLibrary com.yacreader.YACReader
