Arrow keys
- Esteban
13 years 6 days ago #225
by Esteban
Arrow keys was created by Esteban
Hi!
We can use left and right arrow keys for comic viewing. Maybe Up and Down can be used to browse libraries (I've divided my collection alfabetically) and folders while using the TAB key to change the frame.
13 years 6 days ago #226
Replied by Luis Ángel on topic Arrow keys
Hi Esteban, welcome to the forum!
Thank you for the suggestion, I will think about the best way to do that.
- Esteban
12 years 11 months ago #247
by Esteban
Replied by Esteban on topic Arrow keys
Thanks!
See, i've divided my libraries alfabetically (all the letters plus a temp), so there's few space left for folders frame and i´ve to clic in a very tiny space with the mouse to view the folder at the bottom. It would be a lot easier with the arrow keys.
That or make libraries and folders frames resizeables. That would be cool too.
12 years 11 months ago #248
Hi Esteban,
why don't you create a single library in your root comics folder? the search feature only works in the current library. You can keep your alfabetical list as a list of folders.
I will improve the libraries list in future versions.
- Esteban
12 years 11 months ago #251
by Esteban
Hi again.
Initially i did as you suggest but YACReader and windows explorer both turned slow. I suspect that too many folders and files within a single parent folder isn't good for windows. I know that there's always a single root folder. I ain't really sure it's my machine or my disk or windows or even YACReader but having many libraries solves the problem.
Thanks for yor time.
12 years 11 months ago #254
How big is your collection?
- Esteban
12 years 11 months ago #267
by Esteban
BIG. Some day i'll retire and hopefully i'll be able to read a good bunch of them.
Now i've learned that if i clic on any of those small sub folders tiny arrows i can use up and down keys BUT comics won't update... folders doesn't really change.
