Reseting last read location
  • Elecninja
12 years 1 month ago #772 by Elecninja
Reseting last read location was created by Elecninja
There doesn't seem to be a way to reset the last read position for a comic book.
It would be great if it either gives you the option to do so in a button or automatically resets the last read position when the "Last Page" pop up comes up.
12 years 1 month ago - 12 years 1 month ago #773 by selmf
Replied by selmf on topic Reseting last read location
You can use the home key for that :)
Last edit: 12 years 1 month ago by selmf.
  • Elecninja
12 years 1 month ago #774 by Elecninja
Replied by Elecninja on topic Reseting last read location
Definitely possible, but also an annoyance especially when you have large amount of comic books to reset.
You don't want to have to go through each one to reset the position. That's just tedious.
And if you want to reread a series, you will have to keep on pressing the home key every time you reopen a book. Once again a tedious procedure.
12 years 1 month ago - 12 years 1 month ago #777 by Luis Ángel
Replied by Luis Ángel on topic Reseting last read location
In YACReaderLibrary you can reset the read status for the current comic or for all the comics selected. Just use the ribbon button with an 'x' in it.
If you want to select all the comics in a folder you can use the 'double tick' button. For selecting specific comics hold 'shift' or 'control' and click on them (list view).
Last edit: 12 years 1 month ago by Luis Ángel.
The following user(s) said Thank You: Elecninja
12 years 1 month ago #779 by selmf
I think he wants it in YACReader. It's not a bad idea to reset the auto bookmark once a comic has finished. Usually when I open a comic after finishing it I want to read it from the start again. But other people might prefer the way it is now. Maybe we could add a "Reset auto bookmark after comic is finished" checkbox to the options menu?
  • Elecninja
12 years 1 month ago #789 by Elecninja
Both options are fine, but it would be great to be able to streamline it by automatically reseting at the end.
That way you don't need to remember to reset the book after you're done.
