Faster Sync Selection Method
  • Pfantom
  • Senior Member
  • Senior Member
2 years 2 months ago #8629 by Pfantom
Faster Sync Selection Method was created by Pfantom
Has syncing the same menu that appears when you press and hold on an issue or folder been considered? I recently replaced my iPad, and resyncing my library was a hassle. Importing each folder separately, instead of using a swipe or multi-select feature, feels unnecessarily tedious.
2 years 2 months ago #8634 by Luis Ángel
Replied by Luis Ángel on topic Faster Sync Selection Method
If you want to import everything you can select "Import starting here" on the first item...
