Selectable color in container folders
- Joshkerr
1 year 4 months ago #9493
by Joshkerr
Me la sopla y no es el viento
Selectable color in container folders was created by Joshkerr
One option that would benefit people like me who have certain vision problems would be the ability to select different colors for the folders in the list that appears on the left side of the app.
If I want to mark a series of folders as read, I have to look at the tiny black tip, which, even when I increase the screen resolution, isn't quite visible. That's why I think the solution would be to be able to select a color for each folder in addition to that tip (like in the tag selector). This way, everyone can also understand if the folder in question is unread if they've chosen a color they like (let's say blue); if it's reading, it would be yellow; and if it's finished, it would be a rather sketchy green.
I don't know if I've explained myself well; my English is very bad, and Google Translate is even worse.
Thanks/Gracias
Thanks/Gracias
The following user(s) said Thank You: Luis Ángel, churruka
1 year 4 months ago #9494
Replied by Luis Ángel on topic Selectable color in container folders
Thanks for the suggestion, I’ll keep it mind for future versions.
The following user(s) said Thank You: Joshkerr
