Notes related to Tags, choose which ones to view
  • migube
  • Senior Member
  • Senior Member
3 months 2 weeks ago - 3 months 2 weeks ago #10186 by migube
Hi Luis
FYI there are some new formats related to Tags (metron)
comicbox.readthedocs.io/TAGS/
shows a corrspondance might be usefull if you ever need/want to implement some other tags compatbility.
For now I'm using the Comicinfo.xml, and one of the parameters I use is <web>
Could you let the users display extra tags, ex in the HTML page view if that's easier? or show them all?
Is it also possible to mark/filter/view the comics that don't have or do have comicinfo.xml /tags available and the one that don't?
tx
in the meantime if you could add to github.com/YACReader/yacreader/blob/deve...ot/js/webui.js#L1547 var metadata = [
["Series", comic.series],
["Issue", comic.universal_number],
["Count", comic.count],
["Web", comic.web],
assuming those are added in the DB I didn't check :)
ps: would be good if the urls in Web are clickable :-)
MG!
Last edit: 3 months 2 weeks ago by migube.
