Yacserver Library view allows me to Tag & Scrape:)
  • migube
  • Senior Member
  • Senior Member
3 months 2 weeks ago #10191 by migube
B) Thanks again for the Yacserver Library View, which is for me easier to play with vs the Windows version.
So what I did to play, reusing my existing Tagging tool
0) I choose a new comic that isn't tagged or named correctly
1) Using a Web snippet Bookmark, I send the URL to my tool opening another webpage
2) I parse the comic ID and look up the comic file and folder from the sqlite3 library
3) with this I m all set and I can use my usual Scrape/Tag updates (like Web Tag) to update the comic file, change its name,... in the background
I just need to still manually refresh the Livbrary/xml changes still in the Windows Yacserver, pending that you enable such button from the Web Page too ? :)
Muchas Gracias !
cr
