Export List of Missing Issues from Series / Volume
  • dbb1480
3 months 6 days ago #10216 by dbb1480
Hello
I think yacreader would be probably the perfect comic library if it had a way to export a list of issues you were missing in your series folders. For example... Action Comics (1939) - missing issues #691, #702, #916
2 months 4 weeks ago #10233 by migube
Hi dbb1480
the way I do it for now
1) I add in the comicinfo.xml the Web URL's of the Comic Site (I used bedetheque for french comics) containing the info :
e.g. www.bedetheque.com/BD-Arcane-majeur-Tome-1-Pandora-23648.html => Album URL
and m.bedetheque.com/serie-5709-BD-Arcane-majeur.html -> Serie URL
2) I add the #issues in the comicinfo.xml from the Serie URL count , here it's 6
- Once and a while (you never know there is a new album) I launch a script updating this info back into the xml file)
- and while at it, it counts the amount of files in the folder pointing out if the amount of files is less than the amouint in series (assuming a structure of series_folder/ one file per comic)
or: In Yacreader it shows 1/6 for the first comic, telling me it's the first out of 6... and in Yacreader I can see there are only 5..
Same is valid for the Yacserver webpage, it says 5 files, and clicking on the first comic shows 1/6 ...
Not ideal but the only way I found for now to get an idea of amount of missing comics
cr
2 months 3 weeks ago #10239 by migube
note, that I've been playing with Claude Desktop...
I just provided some filenames (or comicinfo) or oher info telling it to check the bedetheque.com site, and it glady told me which missing Issues there are..
Myabe that's a next step... have some AI options connecting to e.g. local LLM's like Ollama, or Claude or others, and launch queries regarding the comics ?
it could do a lot..
of courese, assuming local LLM's will stay local, might be better..
