Open with...
  • Pinafal
11 years 4 months ago #1429 by Pinafal
Open with... was created by Pinafal
Pretty simple request but how about adding open with to the context menu for files like zip, rar etc. Saves the time and allows quick checking before putting into the library.
Keep up the good work!
11 years 4 months ago #1439 by Luis Ángel
Replied by Luis Ángel on topic Open with...
Welcome to the forum!
Thank you for the suggestion. You can drag & drop files into YACReader, it is a fast workaround.
11 years 4 months ago #1440 by selmf
Replied by selmf on topic Open with...
it's not clear to me what kind of feature you want. Do you want to have YACReader integrated into you system so you can right-klick on files and "open with YACReader" appears as an option? Or do you want the possibility to open files in YACReaderLibrary with an external archive management program?
The first one can be achieved by registering YACReader as a file handling program for the respective archives, the latter would require support for specifying an archive handling program.
Regards,
selmf
