Change default port to avoid conflicts
  • robson.sobral
  • Premium Member
  • Premium Member
11 years 4 months ago #1487 by robson.sobral
Change default port to avoid conflicts was created by robson.sobral
`8080` is a port used too often for different apps and this causes conflicts.
Syncthing, on same situation, changed its port to `ST` in ASCII values: `8384`.
Couldn't YACReader use the same idea and change the port to `8982`, which is `YR` converted to ASCII numbers? Or something like this...
11 years 4 months ago #1491 by Luis Ángel
Replied by Luis Ángel on topic Change default port to avoid conflicts
YACReader tries to use a different port if any process is already listening in the port 8080. Changing the port in the server dialog is not a big deal.
