- Thank you received: 8
Don't lose selection focus after reading a comic
- Qulox
- Senior Member
11 years 1 month ago #1774
by Qulox
Don't lose selection focus after reading a comic was created by Qulox
After reading a comic in the library while in grid mode if I exit the comic and then press the arrow keys the comic no longer is selected and the focus changes to the folder panel, which is kind of an annoyance and hinders keyboard-only reading. If you use the list view and exit a comic the focus is not lost and you can use the left/right keys to select another file.
Also, I have various libraries and in some of them when I search a file the options appears greyed out in the right-click menu when trying to open file location, it doesn't happen in all the libraries but always in the some ones.
11 years 1 month ago #1777
Replied by Luis Ángel on topic Don't lose selection focus after reading a comic
Thanks for reporting the focus bug.
Can you post a screenshot showing your second issue?
The following user(s) said Thank You: Qulox
- Qulox
- Senior Member
11 years 1 month ago - 11 years 1 month ago #1781
by Qulox
Replied by Qulox on topic Don't lose selection focus after reading a comic
In this library does not work:
www.dropbox.com/s/c8ntn205oju1f1r/Screenshot%20%2817%29.png
In this one there is no problem:
www.dropbox.com/s/sxvuv2ek7ic8hlt/Screenshot%20%2819%29.png
(btw, sorry for the blurring
Last edit: 11 years 1 month ago by Qulox.
