Percentage info when importing (for each comic)
  • skrimaging
  • Junior Member
  • Junior Member
10 years 10 months ago - 10 years 10 months ago #1917 by skrimaging
on the detailed import tab (one that shows each title being imported), Is it possible to add the percentage info for each title...
right now I just see the size of comic file and a yellow progress bar.. would be helpful to see an incrementing % info to give indication if huge file is transferring or blocked...
or maybe even info like 1KB / 32MB -- 2KB/32MB -- and so on for even more detail..
a setting in the app could let user choose if they want % info or file size info to be shown..
Last edit: 10 years 10 months ago by skrimaging.
10 years 10 months ago #1918 by Luis Ángel
Replied by Luis Ángel on topic Percentage info when importing (for each comic)
Thanks for the suggestion. I have to find a good layout for adding more information while keeping the UI simple and clean.
  • skrimaging
  • Junior Member
  • Junior Member
10 years 10 months ago #1921 by skrimaging
Replied by skrimaging on topic Percentage info when importing (for each comic)
Not much needs to be changed in terms of UI placement.. I mocked up a quick UI idea that might help.
see attached photo
