Too Many Libraries
- angelicimagination
9 years 11 months ago #2595
by angelicimagination
Too Many Libraries was created by angelicimagination
I've noticed that if I have more than 25 libraries loaded into the app, it offsets the ability to click on a specific comic. Say Uncanny X-Men is the last comic out of all the libraries I have, I would be unable to select it. Perhaps a scrollbar should appear in this case so that the ability isn't lost?
9 years 11 months ago #2598
Replied by Luis Ángel on topic Too Many Libraries
Basically you only need one library. Please, read the answer to the first question in the F.A.Q.
www.yacreader.com/support
My suggestion is to delete your libraries and just create one in your top level comics folder.
