- Thank you received: 8
Expand on library management.
- Qulox
- Senior Member
13 years 4 months ago - 13 years 4 months ago #13
by Qulox
Expand on library management. was created by Qulox
I,ve been using YACReader for a long time and I love it, but this really needs more management options, for example:
Delete files from the hard disk (send them to the recicle bin).
Rename archives and folders.
A tag option.
An option to view only unread items (That would be great).
Even if YacReader could include only one of those I would appreciate it a lot.
Regardless of any change I will keep on using it.
Last edit: 13 years 4 months ago by Qulox.
13 years 4 months ago #15
Replied by Luis Ángel on topic Expand on library management.
Hi Qulox,
Thanks for using YACReader and for your suggestions.
What does "A tag option" mean? The other features are already scheduled for further releases.
- Qulox
- Senior Member
13 years 4 months ago #16
by Qulox
Replied by Qulox on topic Expand on library management.
Hi there,
I mean an option to create custom tags for your comics and that they appear on the sidebar on the Library. Could be like right clicking on the file name (on the library) and "add tag".
- lobo
13 years 4 months ago #17
by lobo
Replied by lobo on topic Expand on library management.
Yes, tag function is a good idea.
- middle_pickup
- Thank you received: 7
13 years 1 month ago #184
by middle_pickup
Replied by middle_pickup on topic Expand on library management.
Tagging would be a huge feature! I used Ehon for some time before finding YAC, and used its tagging system extensively. It helps you remember which series cross over where, and which characters pop up as guests in other books.
The following user(s) said Thank You: Chocwise
- Chocwise
11 years 8 months ago - 11 years 8 months ago #1021
by Chocwise
Replied by Chocwise on topic Expand on library management.
+1 for the tagging.
Especially for huge libraries it's very helpful if there were tags.
There are a lot of different genres, like SciFi, Fantasy, Romance, Comedy and so on. You could then just click the tag, if you feel like reading some romance at the moment.
EDIT: It seems this already has been adressed with the newest beta version.
Last edit: 11 years 8 months ago by Chocwise.
