Multi-user Library
  • JohnnyD
13 years 3 weeks ago #196 by JohnnyD
Multi-user Library was created by JohnnyD
Both my kids and I love reading comics (on iPad) and sometimes we read the same series. This can make it a bit hard to keep track of which comic I finished reading and which my kids finished. Next to that, the library on the iPad gets cluttered with all those comics.
A solution would be, to have some kind of multi-user system. It would be a minor change for the UI, just an option to log in as a certain user or to log in as an anonymous user and after that, each reader would have his own library.
It should be possible to hide the log-in option for single-user situations (something like an automatic anonymous log-in).
If you like this option and if I can help you out, please let me know!
Cheers,
Johan.
13 years 3 weeks ago #199 by Luis Ángel
Replied by Luis Ángel on topic Multi-user Library
It is a nice idea, I will think about it for future versions.
One of the feature of YACReader for iOS is the copy function. You can copy any comic or folder and you will not use more storage in your device. You can have a folder per user, and copy/cut the comics after importing them. Each comic will have its own current page marker.
Thanks for the suggestion
  • JohnnyD
13 years 3 weeks ago #207 by JohnnyD
Replied by JohnnyD on topic Multi-user Library
Copy? Folder? Mm, I didn't know about these features, I'm going to check them out! :)
Thanks for your reply!
Cheers,
Johan.
13 years 3 weeks ago #208 by Luis Ángel
Look at 0:49, you will see how to select comics for copying, sliding from left to right will select for deleting. To create a new folder, just press the button in the navigation bar at the top right corner ('+').
  • JohnnyD
13 years 3 weeks ago #209 by JohnnyD
Thanks!
