ipad issue: separate ipads overlapping read order
- vomiccinepia
6 years 5 months ago #5211
by vomiccinepia
ipad issue: separate ipads overlapping read order was created by vomiccinepia
so, i've got two shorties (3, technically, but, he's reading a different series), and their progress (one's two behind) is messing each other up. i've got the setting turned off to NOT send reading progress back to server (which is on a mac). any idea what i'm doing wrong?
thank you!
thank you!
6 years 5 months ago #5218
Replied by Luis Ángel on topic ipad issue: separate ipads overlapping read order
If they are reading remotely the progress is stored automatically in the server.
So the solution is to import what ever they are reading, if they use the same device you can put their readings in different folders, copies in the ios app do not take extra space. Or one can read remotely and the other one can import the comics.
There is no multi user support.
- vomiccinepia
6 years 5 months ago #5227
by vomiccinepia
Replied by vomiccinepia on topic ipad issue: separate ipads overlapping read order
no, i didn't think there was multi-user support (i noticed ubooquity has that)—but i do think it's the reading off import vs reading off their local copies.
i'll work on that!
thank you!
i'll work on that!
thank you!
