How to fix moire? / Add some sort of way to fix it
- mimikium
4 years 4 months ago #6776
by mimikium
How to fix moire? / Add some sort of way to fix it was created by mimikium
Moire occurs when I'm reading manga that is a higher resolution than my phone's screen, and I don't want to have to zoom in all the time to fix this effect. I know that perfect viewer on android has a setting that helps fix this by having an image smooth filter that you can set to "Bicubic" resulting in the moire being fixed, whereas if I wanted to fix it, I would have to resize all of the images to fit my screen resolution before importing them to the app. If there isn't already an option that I'm missing that helps fix this, could one be implemented? Thanks!
4 years 4 months ago #6780
Replied by Luis Ángel on topic How to fix moire? / Add some sort of way to fix it
The app doesn't have these kind of filters...yet. On iPad isn't an issue normally, but I recon that this can be problematic on iPhone screens depending on the content.
Let me see if I can add something to the next release.
