Feature Suggestion: Custom Safe-Area Margins for Panel-by-Panel Reading on Phone
- Olesen
6 days 6 hours ago #10358
by Olesen
Feature Suggestion: Custom Safe-Area Margins for Panel-by-Panel Reading on Phone was created by Olesen
I use YACReader extensively and have donated a couple of times to help support its continued development. Thanks for all the great work! The library server is excellent, and I particularly enjoy the trimming and panel-by-panel reading features.
I have a feature suggestion for the iPhone version, although I imagine it could apply to most modern smartphones.
When reading in panel-by-panel mode, YACReader understandably tries to make full use of the available screen space. However, on phones with a notch or camera island, this can create an occasional problem: text and speech bubbles sometimes end up underneath or within that obstructed area of the display.
Depending on the position of the panel on the page, manually repositioning the image to make the text readable can be awkward.
It would be great to have an option that allows YACReader to recognize and exclude these areas from the usable reading space. Ideally, this could work in one of two ways:
Thanks again for the continued development. YACReader is a fantastic application.
- Preset safe-area setting: Automatically account for the notch, camera island, or other obstructed portions of the display.
- Custom margins: Allow users to define their own margins or exclusion zones, effectively telling YACReader which parts of the screen should not be used when positioning panels.
6 days 5 hours ago #10361
Replied by Luis Ángel on topic Feature Suggestion: Custom Safe-Area Margins for Panel-by-Panel Reading on Phone
There is a setting that gives some control over the amount of margins used, I don't know if the largest setting could help right now. But yes, the app needs to take safe areas into consideration. I use YACReader mostly on my iPad so I missed this completely.
Thanks!!
Thanks!!
