Setting up Port Forwarding
  • necromage5235
5 years 2 months ago #6140 by necromage5235
Setting up Port Forwarding was created by necromage5235
Hello all, I am having an issue setting up port forwarding to set up remote access.
I am in my router settings but it is asking for some info that I cannot find on here or anywhere else.
Here is a screenshot with the port forwarding set up
I know the port and IP but I dont know what the external or internal are
5 years 2 months ago #6146 by Luis Ángel
Replied by Luis Ángel on topic Setting up Port Forwarding
External is the port you will using when accessing from outside and internal the port where YACReaderLibrary is running the server on. You can use the same port in both fields.
