cover resolution in comic flow view
  • autopilote
3 years 8 months ago #7410 by autopilote
cover resolution in comic flow view was created by autopilote
is there anyway to improve the resolution of the covers in the comics flow view? the images are not quite blurry but definitely not crisp at all. when i open the comic in the actual reader, it looks good.
3 years 8 months ago #7411 by Luis Ángel
Replied by Luis Ángel on topic cover resolution in comic flow view
There is a setting to configure the quality of the flow, can you check how it is configured?
  • autopilote
3 years 8 months ago #7412 by autopilote
Replied by autopilote on topic cover resolution in comic flow view
what specifically should i be looking at/adjusting?
  • autopilote
3 years 8 months ago #7416 by autopilote
idk what happened to my reply (i tried to add a screenshot and it may have disappeared into moderator land), but what settings specifically should i be looking at/adjusting?
3 years 8 months ago #7417 by Luis Ángel
The performance slider. It should be at high performance to get the best image quality.
The following user(s) said Thank You: autopilote
  • autopilote
3 years 8 months ago #7419 by autopilote
thanks. of course i missed the most obvious thing. it worked.
