Problem with cbr files.
  • jsteweii
3 years 2 months ago #7686 by jsteweii
Problem with cbr files. was created by jsteweii
Hi guys. So, I don't get this problem. What happens is that existing thumbnails in Finder doesn't display for newly added cbr files (all cbr files). Existing thumbnails show up fine. They show up as generic rar archives for the newly added ones.
What I've tried so far:
-remove Quicklook cache and total reset of Quicklook.
-remove any and all traces related to BetterZip, my unarchiver. This gives the default generic Mac rar archive thumbnail.
-of course made sure that YacReader is set as default application to open cbr.
-tried out different earlier versions of YacReader.
-installing Simplecomic for test of quicklook functionality and thumbnails are generated as they should.
-had the cbrs opend with BetterZip and compared the archives all seems good.
-converted from cbr to cbz, no dice and back again also no dice.
-removed BetterZips filehandling in regard to cbr and cbz.
So is this a problem with the new cbrs in relation to YacReader, is it Yacreader itself or something completely different?
Thanks in advance,
/johnny
3 years 2 months ago #7688 by Luis Ángel
Replied by Luis Ángel on topic Problem with cbr files.
YACReader doesn’t provide thumbnails preview, so when you get them is other app doing it. Are you using YACReaderLibrary?
  • jsteweii
3 years 2 months ago #7689 by jsteweii
Replied by jsteweii on topic Problem with cbr files.
I'm not using it for my library, but I created a library to see if the covers would show up there and they did, no problem.
  • jsteweii
3 years 2 months ago #7690 by jsteweii
It feels like Quicklook is messing things up, because i can assign the cbrs to Calibre bookmanager for instance, and then the preview icon changes to calibres default preview icon. And as stated above if i remove BetterZip it gives me macOss default rar preview icon. The existing, working previews doesn't suffer under removal of BetterZip.
