YACReader for iOS - testflight
  • Luis Ángel
  • Administrator
  • Administrator
7 years 1 month ago - 7 years 1 month ago #4719 by Luis Ángel
YACReader for iOS - testflight was created by Luis Ángel
You can joing the beta testing of the iOS app here: testflight.apple.com/join/5zhB7sRP
Last edit: 7 years 1 month ago by Luis Ángel.
The following user(s) said Thank You: all4all, jocala
7 years 1 month ago #4722 by jocala
Replied by jocala on topic YACReader for iOS - testflight
Will YACReader's filesystem be exposed to Files in an upcoming beta?
  • Luis Ángel
  • Administrator
  • Administrator
7 years 1 month ago #4724 by Luis Ángel
Replied by Luis Ángel on topic YACReader for iOS - testflight
Not soon.
7 years 1 month ago #4729 by K1nd3r
Replied by K1nd3r on topic YACReader for iOS - testflight
I try the link but he said no new beta tester the beta was private ?
  • Luis Ángel
  • Administrator
  • Administrator
7 years 1 month ago #4730 by Luis Ángel
No, it is not private. 9.7.0 is being reviewed by Apple for beta testing, you will be notified when it is ready, tomorrow probably.
Betas are only available for sort periods of time before a new version is released.
7 years 1 month ago #4731 by K1nd3r
Oh ! Okay i see, thanks, i watch this later tomorrow.
Thanks for All !
7 years 1 month ago #4732 by jocala
Luis Ángel wrote: Not soon.
Too bad, I was hoping it would be a simple addition. Love YACReader, thanks for your hard work!
7 years 1 month ago #4736 by all4all
Wooov... Luis, u r the man.. MARGIN TRIMMING ROCKS!!!! it is very well implemented solution.
I have tried on mangas, band dessinee s, comics. It works PERFECT!!. it does not trim when the page trim ratio changes per page. it dynamically trims again when white areas popup.
Trim ratio is maximized!!! Excellent!!
Especially French comics gain so much from this solution.
Very Impressive solution Luis thank you so much.
For test purposes, i am using iPad Pro 12.9 inch with os 13.1 beta.
  • Luis Ángel
  • Administrator
  • Administrator
7 years 1 month ago #4738 by Luis Ángel
Replied by Luis Ángel on topic YACReader for iOS - testflight: MARGIN TRIMMING!!!
all4all wrote: Wooov... Luis, u r the man.. MARGIN TRIMMING ROCKS!!!! it is very well implemented solution.
That's something I would like to read in an App Store review after the release :oops:
Thanks for testing the beta!
7 years 1 month ago #4742 by K1nd3r
Like all4all MARGIN TRIMMING was incredible ! The new search bar was really intuitive, i try on comics, manga and french comics too. I have only one problem, somestimes when i'm select a comics whith a swipe for delete or cut or copy, the slide not appear. It's just graphic because the fonction work.
I'm on ipad (2018) 11' iOS 13 Beta
