YACReader pre-alpha 8.0
Luis Ángel wrote:
Thank you. The 'A' is for switching between fit to with and fit to heigh, by default "fit to with" and "fit to height" don't have their own keyboard shortcut, I guess that I should add the switching action to the context menu....Qulox wrote: Bugs I've found so far...
I don't think it's a good idea to switch between two fitting modes. It makes much more sense to switch to a specific mode (switch from "whatever" to "fit to width" or "fit to height"), so each mode should get the possibility to be triggered by a shortcut.
Speaking of fit modes, "show full size" needs some attention as well. If you invoke this mode, it will disable all other fitting options until you disable it. Very annoying. I'd suggest removing the "checkable" status from it's icon and disabling it as soon as another fitting option is invoked.
Currently, every fitting mode has it's own config option. Maybe merging these into a "fit_mode" option would be better?
selmf wrote: Another bug: It's impossible to delete a shortcut. If you try, you get the message "The shortcut "" is already assigned to other function"
Fixed!
Thank you for working on the fitting code.
Btw, I found a regression in the cover flow. In YACReader, it's no longer possible to click on the right side of the flow to browse the preview. Only the left side works.
YACReaderLibrary seems to be unaffected.
Let me know if you need more details or want a patch/pull request/code snippet for that.
selmf wrote: Finally found some time to look into that gl_flow regression. Turns out it's rather trivial. All that is missing is a minus sign in the mouse event code for clicks on the right side.
The code in YACReaderFlowGL::mousePressEvent is the same in both 7.2.0 and current development version. It seems that since the QOpenGLWidget migration gluUnproject is not working properly, I have changed the default config for OpenGL I guess that something is missing.
In 7.2.0 mouse clicks are pixel perfect (x-axis) in the gl_flow, a click on the left/right of the central cover performs next()/previous() navigation.
