PDF render quality problem
2 years 4 months ago #8534 by LethalWeapon
Replied by LethalWeapon on topic PDF render quality problem
Let's not be mistaken either: PDF is an excellent format for Comics.
At the same size and resolution, it does just as well as CBR/CBZ.
In fact, many PDFs run perfectly well in YACReader.
So don't throw away your PDF Comics collection and don't switch entirely to CBR/CBZ!
Just wait for the update, relax and the problem will take care of itself.
2 years 3 months ago #8561 by Luis Ángel
Replied by Luis Ángel on topic PDF render quality problem
There is a new dev build with a patch that bumps the minimun image size produced when rendering a PDF page github.com/YACReader/yacreader-dev-build...s/tag/9.15.0.2406201
The following user(s) said Thank You: LethalWeapon
2 years 3 months ago #8565 by LethalWeapon
Thank you very much Luis for the new version.
Below are two screenshots, the first a CBR 2560px and the second a PDF 2660px. The image is enlarged to 200%.
The quality seems equivalent. No blurring or aliasing, for example on the upper edge of the cockpit canopy or the outline of the pilots' helmets.
No problems either on the files I provided in a previous post, which rendered poorly. The image is now clean.
We'll have to do some more tests, but the problem seems to have been solved.
Thanks again.
See you.
  • inzemix
2 years 3 months ago #8581 by inzemix
Replied by inzemix on topic PDF render quality problem
Hi Luis,
After testing the new build, it works very well on the pdf whivh were problematic.
Thx a lot for the time you spent on fixing this issue !
The following user(s) said Thank You: Luis Ángel, LethalWeapon
